- Oct 29, 2012
- 1,392
Ok, so it's not impossible to join the ends of steel wire that small... I wonder if they'll tell me how they do it?I found this!
Diamond Wire Loop-D0.35 - Ensoll Diamond Wire Loop ,Wire Cutting Machine
Description: Endless Diamond wire loop Model D0.35 is the thinnest endless cutting wire in the world.It’s an tech breakingthough,this kind of wire have a diameter of 0.35 mm,the cutting kerf is very small. If you need to cut very small and expensive material, D0.35 is the best choice. You can...www.toolsresearch.com
I'm curious if they take already-made diamond wire like I have, and splice it together, or if they make loops if steel wire and then sinter diamonds onto it. My money is on the latter.
