- Jul 6, 2022
- 533
When I bought my old lathe, it came with anything I wanted to take from the guys workshop (everything I didn’t take was going in land fill). So I decided to load up on all of the HSS tools:
Most of this is 12mm to 20mm tooling. My Lathe takes 10mm tooling (maybe 12mm tooling if I start using the AXA XL tool holders).
What’s the most effective way to reduce these HSS tools down to a size that would fit my lathe. Im not trying to use the existing form of the tool on my lathe, just reduce them down so I can regrind the tool at the 10mm size (I.e use them effectively as blanks)
Would milling them down work? If so, would I need carbide tooling or would HSS end mills be ok? I think using a cutting wheel would be too difficult when taking the depth down?
