Hey Folks, I took my new vise off a new pristine table after approx being mounted approx 3 weeks. I am seeing lines of darkening. Not sure these are rust as it does not make sense to me based on time, treated surface, and not being particular humid (mid upper 50's RH) and that they are not a color I would expect, just dark. Looking to confirm if these is rust, staining from product, or by product of some other form of oxidation.
Prior to setting it in place, I put a healthy layer of Fluid Film (lanolin based) on the underside of the vise as well as the table. I took the vise off as I need to lift the mill to set its trip tray, and had left it off for a bit over a week, went back today to put it back on and after wiping the table was surprised to see dark marks corresponding to the relieved parts of under the vise and its outline.
The lines correspond to where the heavy deposits of Fluid Film were. The underside of the vise also had the same markings, again where the heavy lines of film where. I dont know if they were there at removal (since I did not wipe them down as I probably should) versus after sitting off for a week. My though is this product is the type that suspends moisture and that possibly too heavy a layer is a bad thing?
The lines do not remove with solvent. Non reactive to rust product like naval jelly. Come off with scotch brite pad.
Thoughts?
