- Jan 28, 2020
- 208
David's book contains tables of recommended indexable tooling for basic, intermediate, and advanced level projects. I think that these tables can be useful for HSS tools as well, as many of the tools that David lists have HSS analogs. For example,HSS is great but you do have to learn to grind them. In the meantime you still need to learn to use your lathe and carbide tools are not a bad way to start. My usual recommendation is to use GOOD (Kennametal, Micro 100) brazed carbide tools first while you learn to grind HSS. If you prefer inserted tools then either go with AR Warner HSS inserts or buy David's book and learn which carbide tools you should get. ...
- 80° rhombus insert with its various turning/facing toolholders is equivalent to tangential/diamond tools in HSS.
- 55° diamond insert in a RH turning/facing toolholder is equivalent to the a RH knife tool in HSS.
Thus the tables can provide guidance on how to prioritize grinding the various HSS tools.
