- Sep 1, 2023
- 914
So the mini-lathe looks to be the standard Real Bull pattern with a brushed motor.We are quit of topic but it shows that using carbide on non rigid desktop hobby lathes can give good results.
Both my lathes are from HBM, a company in the Netherlands that sells hobby level lathes. Both lathes needed a full service and some tweaking right out of the box but are now repeatable and accurate.
- HBM300, 70 kg, 21 mm spindle bore, 80 mm chuck, BLDC 500W, contact angle bearings, 15 years old
- HBM BF290, 300 kg, 38 mm spindle bore, 160 mm chuck, 1.5 kW brushed DC, tapered roller bearings, 6 years old)
Most of the time I use the lathes in CNC mode so I can set the feed, speed and cutting depth accurately and repeatable. In manual mode I can take a 1 mm depth of cut in mild steel (hot rolled) but only because I feed much slower than in CNC mode. The finish however is like the cutting sound, not good. To me, that isn't a surprise because I have done extensive feed and speed testing on both my lathes so I know what to expect.
I can cut deeper than 0.5 mm in steel, but not with a finish suitable for a bearing fit.
My bigger lathe is more rigid than the small lathe but still not rigid. If you look at the picture you see a massive stud for the tool post mount. The tool post it self is flimsy and has a lot of over hang. If you set it at full extension (70 mm range) the overhang increases. I added 4 aluminum studs to support the tool post and that makes a real difference. If I have time, I will replace the whole setup by a solid tool post support. In CNC mode, the tool is placed above the aluminum studs and the gibs are adjusted (locked) to maximize rigidity. That makes things better.
Even if I can't take heavy cuts, I have no problem getting a decent finish on any of the steel (most of is is unknown type) I have in stock and (CNC) turning to 0.01 mm diameter tolerance requires 3 finish passes of the same cutting depth and one measurement before the last finish pass.
Most of the time, I make small ( 3 .. 40 mm) parts (prototypes) so taking heavy cuts isn't a real option most of the time.
HBM BF 290 lathe later version
HBM 300 lathe later version
The tool post setup of the HBM BF290 lathe.
These really can benefit from a bunch of adjustments and upgrades. Steve Jordan has a lot of videos about improvements that squeeze out about as much rigidity as is possible from the bed, headstock and tailstock design.
Unfortunately Steve's cataloguing of what he covers in the videos via the titles isn't optimal so you do have to watch most of each particular video to catch some of the important information.
Still and all they're worth checking out.
The motor can be upgraded to a brushless motor (Custom Crafter, a member on this forum, offers a whole load of different options and if and when I do the motor on my little 7x, I'll probably get it via him).
Just upping it to a 1HP (750W) motor should give you a fair bit more torque and with the mechanical advantage you have with the hi/lo gearing in the headstock you probably will end up with more torque than the Seig SC3 model which has a brushless motor but no Hi/Lo gear.
Obviously adding extra stiffening parts (like a central shear plate under the saddle between the ways and chunkier rear and front shear plates) like Steve Jordan does, and upping the torque available can't get you beyond the underlying limitations of the rigidity of the bed (the improvements and upgrades just make sure you don't leave any unutilised sources of rigidity on the table, so to speak, so will help), and if the saddle/cross-slide and compound aren't adjusted optimally then there'll still be rigidity issues.
