Have a look at this web site
http://www.freechex.net/
They have an easy to make tool that punches out gas checks from aluminum soda cans.
Cast lead bullets will require a gas check when pushed to speeds over 1200 fps. You can get away without them if you keep the velocity down and use harder lead alloys.
The mold for a gas check style bullet is different (as mentioned in other replies) than a regular bullet mold.
I regularly push my .357mag revolver loads (without gas check) past the 1200 fps point with no ill effect other than some mild lead fouling of the rifling grooves.
A "Lewis Lead Remover" from Brownells.com is great for removing lead fouling. Check out the video of it at
http://www.brownells.com/gun-cleani...ead-remover/lewis-lead-remover-prod21587.aspx
This Lewis Lead Remover really works well. When I pull it through a heavily fouled barrel, long slivers of lead come rotating out of the muzzle just ahead of the lead remover patch.
