Thanks for all the info. I'm in the drill press so cheap that I wouldn't be upset spending $340 on my VFD install, especially if I get an auto-reversing tapping feature in the bargain.
If I can remote mount the display and E-stop button on the front of the drill head, it will be very clean and easy to operate.
I am cheap so I'm looking at the ammo can enclosure and the 10AWG VFD cable. I do know that 10AWG is smaller than 8AWG, it's also much cheaper. I haven't found 12AWG any cheaper so it seems like the right fit (I never turn away free copper). Inside the electric box on the Marathon motor, the wires look like 16AWG or at most 14AWG. It seems like wire nuts are the cheap and good system, I guess people use Wago to make things easy which is ok but I don't mind twisting on a wire nut...
For the 110v side, I will probably have 12AWG, possibly in an IEC cord to make it easy to replace.
I'm still not quite clear on how to do a braking resistor. Reading the manual I haven't found a part number or resistor specs yet.
As long as the cheap capacitive filter and cheap ferrite motor wire filter can fit in the ammo can, I think I'd like to incorporate them.
The filter used to avoid radiating noise back on to the 110v wiring seems more expensive. I would like one but it sounds like a piece I can skip probably.
I will call up Automation Direct with my questions on Monday probably.
