I'm thinking of a DURApulse GS20 VFD for my new to me Rockwell radial drill press (15-127) which has a Marathon 1/2 hp 3 phase 230/460v motor.
There are accessories mentioned like line filters, shielded motor wires and a sheet metal piece with cable glands to kind of seal it a little.
It's going to be run in a shop with some dust and potentially a little smoke from cutting fluid.
I don't want to introduce too much noise on the AC lines.
I know I have 110v available in the shop, not sure about 220v.
So first thing, specs:
Is it a bad idea to buy a 1hp VFD for a 1/2hp motor? If I have 220v, how about a 3hp VFD? If it is a bad idea, why?
Can I add a 5 conductor twist-lock connector to move one VFD between multiple 3 phase motors?
Shielded wires? All of my cable runs should be short.
Should I try to do a star ground to avoid loops?
I heard the GS20 has memory for a few motors, has anyone successfully done VFD swapping between tools like that?
Doing it right:
I want a mechanical E-stop button front and center. The NEMA versions have an optional safety interlock switch, is there a good way to do that without spending an extra $3-400 on a NEMA version (that doesn't work on 110v)?
What filters and other stuff should I add to protect the VFD and reduce injecting noise in to the power lines and RF noise through the air?
Is the DIN rail mounting kit substantial enough to mount the VFD on the head of the drill press (with cables hanging) or will it be falling off the rail all the time?
Getting fancy;
I was looking at two drill presses at auction, the one I got and a more typical floor mount press with a drill that has an auto-reversing tapping feature. Can I add some micro-switches to the quill, a stopping resistor and a few buttons or relays to make an auto-reversing tapping feature?
I am really looking for DIY examples of one or all of these things and I want to do it right so I don't spend a lot and then smoke my VFD.
Thanks for the help.
Doing it right:
Getting fancy;
