- May 2, 2021
- 330
Shop is about 1.5 hours south of where I live currently.
Headed down to sign lease mid week.
This discussion excellent warm up.
Will shoot more pics when there.
Jim - that picture is an education on its own. Great!
Thinking through how I might set up.
Variables included cost/complexity/DIY/existing equipment.
Clear now I have some options.
Current thinking:
My TIG welder is a 220 single phase.
So 208 single phase circuit is on the table (will check with manufacturer regarding 208).
5BVK would nicely plug in to a 220 single phase - runs great now as such.
So two outlets - ea. 208 single phase makes sense to me.
As for the 10EE - current set up works - but not ideal in my view.
It runs off 460V 3-PH.
Diagram of existing set up below.
Basic set up. House 220 1-PH, bumped up to 440 through reverse knock down transformer.
Looks like from tag that is only single phase - so might not be able to re-use if I want to get rid of the RPC
Which I do. It's loud, and probably undersized at 5HP. Preference would be to use the 3 phase.
Think what is required is either 3 phase Wye 208 delta to 416 (or 440 or 460) up converter.
Or
Run a 3 phase knock down transformer in reverse.
From what I read - requires "Corner grounded" system (not sure what that means), amongst other things.
Not sure exactly what that means.
Or
Additional 208 single phase outlet - and just plug it in like I have it now with RPC
Any help identifying what Wye up converter would do the job on 3 phase 208 outlet would be welcome.
Existing 10EE
Tag on my 10EE (Sabina DC drive)
Edit - this is the paper work I found in my 10EE RPC cover.
Suspect it is showing the buck converter that takes it from 440 to 460.
Note "Connected" verbiage.
The connected 440 is a picture from the RPC box itslef.
Think it means that the RPC is set up to receive 440.
Current thinking:
Or
Or
Existing 10EE
