- Sep 3, 2023
- 352
I need some advice and opinions here. My vertical bandsaw uses a 12'2" blade, 1/2", and I'm currently thinking about getting a carbide tipped blade. They're quite expensive, over $250. Should I do this or is this a waste? I cut all kinds of stuff from stainless to plastic and occasionally lop off a stick of wood. The saw (Jet VBS-900) has a very wide range of speeds, so I try to optimize that for the material.
It all depends on what you really cut that needs carbide. It may be the last blade you ever buy, or just a very expensive lesson.
My experience with a carbide blade didn’t quite go as I wanted. Back story, using a horizontal Jet bandsaw, 1” blades. Can cut up to 12” wide, I think. Saw used in a hydraulic shop cutting chrome rods, cast iron rounds, aluminum round stock, and steel tubing.
Occasionally I have to cut induction harden chrome rod. I usually have to machine or grind thru the harden chrome layer to cut with normal blades.
We tried a carbide tooth blade at around $250-300. Currently we only put it on when we actually have to cut a induction hard piece. Due to an operator error, as happens most of the time, we chipped several teeth. It still cuts fairly well, except for a couple spots with missing teeth. We just slow the hydraulic feed down slower when using.
Personally, I can’t justify the amount of cuts we got from this blade for the cost.
Your situation may be different. Especially since you will be the one operator and having paid for the blade yourself, you may take better care of it, than typical employees who just say, this is broke, I do not know why, get me a new one.
