- Mar 26, 2018
- 8,759
Have you ever replaced the Oriflex orings on a Brown and Sharpe Micromaster? Or had the spindle unit out?
When I removed the spindle unit to replace the bearings I was able to remove the orings due to the angle of the motor.
Upon reassembly I’m hoping there is a trick. It’s very tight quarters to say the least.
Thank you,
Thank you,
