Realized that I replied, but not directly to you: My mistake. I estimate the spindle centerline to compound to be 0.947". Can you check that with yours?
I used a 0.786" rod (20mm) in chuck and measured 0.554" from the bottom of the rod to the compound
cl_2_cmpd = rod_dia/2 + bottom_of_rod_2_compound = 0.786/2 + 0.554 = 0.947"
I will check the measurements again, but I think they are ok. Caveat: Done with dial caliper. Remeasured rod diameter with micrometer: rod_dia = 0.7867", almost the same.
For what it is worth, the toolholder is 1.614" high. The distance from the bottom of the toolholder to the top of the blade is 0.994". This is my measured version of
dimension A in the Aloris drawing.
So this toolholder can't work as is. It is about 0.047" above centerline with no adjustment possible. (The toolholder is sitting on the compound, it cannot go lower without modification.) The height will obviously vary a little depending on helix angle. For these measurements I had a helix angle of near 0 degrees, which is wrong, but is a lot easier to measure consistently.
I did call Aloris. They said they would work with me. Anyways, they asked what the spindle centerline to compound height was. I didn't have it, so I just measured it. Need to call them back this afternoon with the information. Their "drawing" on their website shows Dim A = 13/16" (0.8125"). According to the drawing, Dim A is the distance between the bottom of the toolholder to the top of the blade.
axa-8 product page My measured dimension A is 0.182" greater than the drawing dimension,
which seems like a large discrepancy.
Yes, I realize I could machine or grind the tool or holder. I may do this. Will need to remove at least 0.050", just to have any adjustment.
Looking at the part more closely, I see 13/16" is about the half height of the toolholder. However the drawing shows it is distance from the top of the blade to the bottom of the toolholder. I don't know, am I misreading the drawing? What's the point of this dimension? Is it when the blade is used up? Seems like one could grind off more.
I called Aloris, but could not get in touch with the gentleman I spoke with earlier. I will call customer service directly and see if I get anywhere.
