- Dec 18, 2019
- 7,725
Just received an AXA-8 threading tool today. It seems that I can't quite set the tool to centerline. It's too high. The tool holder is bottomed out on the compound. Can't go any lower.
How are the adjusting screws set? What should the angle of the cutter be relative to the tool holder? There was no paperwork with the tool, which was drop shipped from Aloris.
I measured dimension A and B on my tool. I get A = 0.985" and B = 1.615"a. Aloris says that A should be 13/16", and B should be 1-5/8". Dimension A is hard to measure with calipers, so it's possible that number is slightly off, but it is nowhere near 13/16". Sanity check picture with scale shows similar results.
I was going to contact Aloris, but thought I'd check here first. Could be something I'm doing wrong? Seems weird that Aloris would be 0.173" off on their own print?
Although it may look like it, I'm not threading that rod. That's a ground rod for checking RDM. I needed something for the scale to rest against.
