- Oct 17, 2018
- 966
11. (could be #9 continued, but let's go with 11): I've started looking for parts that I need and took a closer look at the change gears on the side. Here is a picture of what came with the machine. It appears to be set up for 0.005" feed (see chart) instead of the "standard" that is shown in the parts manual (see below for specifics). Am I correct?
A: spindle-fixed, isn't changed for threading, feed rate, etc, correct?
B: 24 tooth gear
C: 20 tooth gear
D/E: 32/16 tooth compound gear, isn't changed for threading, feed rate, etc, correct?
B, C, D, and E are part of the reverse/forward mechanism, and are not changed for threading, feed rate, etc, correct?
F/G: 48/20
H/I: 52/20
J: 54 connects to lead screw, correct?
The parts manual calls for F/G to be 56/20 and H/I to be 64/20 and J to be 64.
So it would appear I need the following change gears:
24, 32 (2), 36, 40, 44, 46, 54, 56, 64 (2), and 50 and 60 for metric threads.
For reference the set called for in the parts manual is: 24, 32 (2), 36, 40, 44, 46,48, 52, 54. I think I have 48 and 52 (F, H).
It also appears I need the 9-70A bushings that go in the gears. Correct? None of the change gear sets come with them.
Can someone confirm/correct this so I can start looking for a set and/or individual change gears? Thanks!
B: 24 tooth gear
C: 20 tooth gear
F/G: 48/20
H/I: 52/20
