You can buy sulphuric acid, or you can buy battery acid. I stated, very clearly, I used battery acid. If you buy battery acid it is clearly labelled on the container it is 35 percent sulphuric acid. I don't know what lab you worked in, but dilution rates are measured by weight, not volume. However, the dilution rate is not super critical.
