- Feb 1, 2015
- 10,109
In my experience a soak isn't required for annealing copper. Certainly, not an extended soak. It may be due to the high thermal conductivity drawing heat away as you anneal it. By the time you reach a higher annealing temperature, the annealing process has begun.
The references to lower temperature annealing ythat I had seen were for wire drawing processes and they did use an extended soak time.
