A DECENT CHUCK???
Make an aluminum backplate- bolt on a hunk and turn the face to match your spindle flange then flip it over and turn the face to match the chuck register
Eminently do-able and actually easier than making one for a threaded spindle
My mini-lathe spindle plate has holes for both 3 and 4 bolts. If yours has only 3 you have a couple options, either make or buy an adapter plate, or modify the lathe spindle plate to have 4 holes. The last option, in my opinion has more chances to mess up, so I'd recommend the first.
Using your lathe you can make such an adapter. When I started out I would forget that I had the capabilities to make things at a level far beyond my pre-lathe days. Unlearning helplessness is hard. We can make stuff, given the will and desire.
That being said, sometimes it's far cheaper to modify existing parts to get to the end. If you can find a disk of steel you can make an adapter plate from it. It need not be cast iron. Or modify something from Little Machine Shop.
There's few rules in machining, whatever gets you to the finish line is all that matters. You don't have to do things the optimal way, just a way that gets you to where you need. Making stuff is how you learn, making mistakes teaches both what not to do and what works. Learning from others often helps us make fewer mistakes.
Wobbly is right- temporary kludgey setups are perfectly ok, it's the result that matters
It goes without saying, don't go out of your way to do "stupid". If you approach the problem cautiously, but methodically, things don't have to be optimal in order to get good enough results.
The spacing is more a function of the manufacturer rather than the chuck size. You might get lucky but I would expect the hole size/bolt pattern will be different for most any chuck you'll buy. One can get the bolt size and hole diameter for most chucks online to verify. If you know someone with a mill it is a relatively simple task to drill a new hole pattern into an existing back plate.
Have in my stuff a 3” 3 jaw with appx .800” thru hole. Backplate covering up brand. Not Chinese. Use it on my small Dayton dividing head. Could use on my 9” south bend when I get around to it.
