- Nov 24, 2014
- 3,445
If "any tool and die maker of any experience and training and they will tell you the same thing", shouldn't there be plenty of credible published documentation? Where are the text books? Where is the credible published documentation? Were they all trained by word-of-mouth?
The Pythagorean theorem is important in machining and tutorials with solution calculators for right triangles are all over the place.
Where is the credible published documentation stating there must be zero gap between the faces?
The Precision Matthews document linked (reply #18) by @xr650rRider says any gap should be filled with a shim. OK, that's one document for the zero gap side. Each reader/owner will decide for themselves how to respond to that document.
I think making a steel shim (the size and with the holes required for my D1-4) precisely flat, parallel and a few thousandths thick is a difficult task. I suppose a shim could be CA glued to the chuck to prevent contamination under the shim and prevent the shim from being a loose part subject to damage.
I hope Kitagawa responds to @Dabbler.
I also sent the following to Pratt Burnerd America (info@prattburnerd.com)
Hello, 2024-09-26
Please refer the following to an expert in manual chuck mounting.
When I mount my D1-4, 3 jaw chuck, there are a few thousandths of an inch of clearance between the planar faces of the spindle nose and the back of the chuck. My question is, is that a proper mounted condition or must there be zero clearance between the planar faces?
All related surfaces are free from damage and contamination and the cam lock pins are properly torqued.
If zero clearance between the planar faces is a requirement, I would like to read a document defining the requirement. Can you provide me with the documentation of the requirement or inform me precisely where to locate it?
Because achieving such a requirement would require lapping the chuck taper to match the lathe spindle taper, I wonder if you can provide a recommended procedure for the lapping.
Regards,
If I get a reply, I will post it in this thread.
Hello, 2024-09-26
Regards,
