- Aug 22, 2012
- 4,292
I did a lot of fettling when I first recieved this lathe but as it was the first lathe I had ever used there was everything I didnt know or have experience with.
I adjusted and checked everything I could after heaps of research on line.
Mostly I used logic to work out how to do it and Cletus's books.
The first set of half nuts were damaged in a crash, totally my fault.
I rebuilt the worm carrier with brass inserts that stopped the key dropping out from excessive end play on the worm.
drilled larger holes in the half nut dove tails so they could be aligned fully and removed all the play.
Made sure they opened and closed fully.
Everything worked well and I have cut heaps of threads with no problems.
I think the main problem was having removed the saddle a couple of times since and never checking how they clamped before tightening the saddle bolts is what caused the problem this time.
I've run a quick experiment regarding the bicycle innertube cover idea and it looks like a good possibility. I will report back if I get it working.
There must also be a better way of preventing swarf from entering the rear of the saddle.
Oh how I love these type of problem solving exercises
