Yes, the same as my Grizzly 602 and my Atlas/Craftsman 6 x 18.
The Grizzly 9 x 19 (G4000) and IIRC, the Enco and HF as well, do have the separate feed system. Savarin had mentioned the keyway that is characteristic of the separate feed so presumably the half nuts are only engaged for threading. Which is why is would be puzzling to see so much wear on the half nuts.
If the half nuts didn't completely disengage when the power feed was being used, they would be sliding over those sharp lead screw threads which would be wearing them down.
