Todays job was making a new cross slide nut from some brass sponge as a test. I will eventually do this in bronze and hopefully solid metal not a spongy mess.
Chopped a chunk from some failed casting and faced it off.
Flipped it and faced again
I kept it as large as I could just in case.
then turned the fixing spigot.
Drilled and tapped then filed to fit the gap in the saddle casting
With such a long thread it is very smooth and not much side play.
I need to add a couple of shims on the top of the boss as if I tighten the fixing screw very tight the movement becomes stiffer.
All bolted up and a nice smooth movement with extended travel both fore and aft.
When the M10x1 die arrives I will cut the shaft 12 mm shorter and use two M10x1 locknuts to fix the handle.
Compared to the original its now joy to use.
