Thanks Chuck,
The first baffle is the internal edge of the tube where it screws into the first brass joiner.
This is why the front of the scope has that large black casting to bring the diameters down so the tubes would not cause any vignetting, the second baffle is a thin internal edge in the middle of the second brass joiner, the third baffle is the internal edge of the focusser tube.
Everything inside is painted with a spray can matte black then top coated with thinned Artists carbon black acrylic.
I taped the ends of the tubes, poured the artists paint in and swirled it around to coat every surface, drained it and stood the tubes on end to drain fully and dry.
Of all the matte black paints I experimented with the "Atelier Artists Acrylic" Carbon Black was the flattest and blackest paint I could find.
The paint
Shots where the camera is just sitting pointing down the full length of the scope.
Unpainted inside
Spray can matte only
overcoated with the artists matte
Those two grey dots at 7 oclock were popped bubbles since been smoothed down and re-touched to remove them.
Simple test but looks "black hole" ish to me.
