- Aug 22, 2012
- 4,315
It came out parallel ok which now let me mark it out for the next three sides so back onto the tool post to remove the waste.
I must have listened to you guys too much and thought I could do no wrong. I got a tad impatient and attempted to speed it up a bit.
ARGHHHHHHHHHHHHHHHHHHHHHHHH disaster
It started chattering and pulled the tool out of the chuck and I took a huge divot out before I could stop. I will have to place one on the other side and call it a feature.
I think that part of the problem was not just the extra speed but the tool bit wasnt quite right so I ground the back of a drill bit so I could turn the cutting edge to the correct orientation (as I saw it) to hopefully not do the same muck up again. This cut very smoothly.
Now all 5 sides are cut I can drill the holes for the bearings and bolts.
Clamped at 45', first holes at 3.3 mm then 10mm clearance for the 9mm dia bearings.
Then back onto the lathe to bore the 53mm dia hole for the focusser tube.
Once that was bored I could cut the apex of the triangle off
The design is not my idea its from this clever gentleman http://jimshomeplanet.com/CrayFocus/CrayFocus.html so credit where it is due.
Thats it for a couple of days as I have to lay a heap of pavers in the back yard. (a large honey do)
