POTD was modifying an ER32 collet rack I have mounted to my Bridgeport. The rack has Delrin or some other sort of plastic material pins screwed to an aluminum base, collets slip over with a little bit of an interference fit. It makes for a handy storage area for the collets and other "stuff" though I think I've only ever used the 1/8", 3/8", 1/2" and 3/4" collets.
Bridgeport collet rack with an electronic edge finder, ER32 collets, 3/4" combo wrench, spanner wrench and straight-shanked drill chucks.
I bought a couple of the Rocky Mountain CNC Solutions ER32 bearing-type collet nuts so out of laziness I could leave the frequently used collets already staged with a nut. Problem is, I didn't anticipate going that route years ago when I made the tray and didn't allow space for the nuts side by side. I figured the easy solution was to make some new longer pins for the heavily used collets.
Grabbed some plastic at hand and faced, tap drilled for a 10-24 thread, tapped, parted, flipped and turned a shoulder on the opposite side for a slip-fit with the ER32 collet.
Easy-peasy. . . Went to screw the pins on the rack and the screws were REALLY loose. The 10-24's didn't touch a thing. . .
Lessons learned for me, but apparently all 10-24 taps are not the same? New one on me.
10-24 tap up top, Morse "10-24" tap on the bottom
The no-name 10-24 tap OD was 0.1935ish, Morse 10-24 was 0.2465?!?!
Did I miss something on this labeling?
The Morse 10-24's were WAY over-size. The book on a 10-24 thread is an OD of 0.19" (Google), and a minor diameter of 0.1379". The Morse taps were 24 tpi, so the delta between major and minor should be the same. That puts the minor of the Morse taps at 0.1944" or clearance for a 10-24 screw. I included a picture of the tap packaging above. Maybe I missed something in the labeling? I understand there are different classes of threads, but whoa! In retrospect, I thought the tapping on the lathe was going a little hard and the tap did look large. I guess check twice, cut once.
I could have drilled out the aluminum plate to accept a larger screw for the oversized pins, but don't happen to have any 1/4" x 24 screws. . . I thought maybe mislabled metrics, but the OD would work out of 6.26 mm and the pitch was dead on 24 tpi (not 25.4 or 1 mm pitch).
New pins on collet rack
Easy grab and go with the collet nuts already on the most-used collets.
I ended up remaking the pins which threaded a little easier on the lathe with the correct tap. By the way, those Rocky Mountain CNC Solution ER32 collet nuts are VERY smooth. I bought them directly from the factory in CO for $20 each delivered.
Thanks for looking, Bruce
