Do you have the part number or plate information of that Dayton motor handy to post?
My imported drill press is the first cousin of yours and sometimes I wonder how long the stock motor will last. It's awfully noisy and runs rough, although it was pretty much like that from new. Since I already have a mill with a VFD, I wouldn't consider spending that kind of money on a light, imported drill press, but it's still useful enough that I would buy another single-phase motor for it. When buying another motor, the obvious choice for metal working is to use a slower 1140 rpm motor.
I used a link-belt to help lower the vibration on my drill press.
This one "belt" was purchased from Harbor Freight which was enough for the two separate belts. These things stretch quite a bit at first so be prepared to remove a few links the first couple of weeks it's installed.
When I was installing the link belt I discovered that the idler pulley wouldn't move back and forth. It's attached to an arm that is meant to pivot in the headstock casting but mine was rusted fast! I guess they forgot the grease and it rusted-up on the boat ride from China. With some penetrating oil and a pry bar I was able to pop it loose and once cleaned, oiled and re-installed, it moved easily. With the idler free to pivot much of the vibration went away, so that's something to check if you own one of these drill presses.
