- Jun 14, 2014
- 410
Hi Friends,
This one is not very glamourous or precise but it got me out of a pickle. While replacing a shaft end encoder at work, I slightly cross threaded the threaded hole in the end of the shaft. I went back to the shop, looked but found no tap that would fix the threads. So I took the mounting bolt from the old encoder cut a slot in the middle of it (see picture) and screwed it in the shaft hole to repair the threads.
The edges at the bolt threads from my cut are sharp enough to repair the female threads in the shaft. However, this "tap" only lasts once or twice, it won't cut new threads and it won't work on badly damaged threads.
I had been using this trick for years with damaged pipe female pipe threads and odd ball female threads that a Grade 8 bolt would work instead of investing in an expensive "real" tap.
Happy Trails
Happy Trails
