- Apr 28, 2014
- 3,594
I find myself using a dial indicator quite often to measure carriage travel on my CT1440G lathe. I saw a picture of a Hardinge lathe with the optional carriage travel dial indicator attachment installed and decided to try and make something similar for my machine.
With no convenient place to mount anything to the front of the gear box or switch box I decided to make use of the empty space inside the switch box. I used a length of 1/2" cold rolled for the shaft, a 3/4" by 3.5" bolt for the mount and an old diesel engine wrist pin for spacers. I faced off the bolt and drilled it lengthwise then reamed it to .502" for a nice sliding fit for the 1/2" rod. Then I bored the inside of the wrist pin to fit over the 3/4" bolt to use as spacers. Even though the outside of the wrist pin is very hard, the inside was easy to machine with a carbide boring bar insert. I drilled and tapped one flat of the bolt head for an 8mm set screw.
I drilled a 3/4" hole in the thick sheet metal of the switch box to fit the bolt, then mounted the assembly into the upper rear area of the switch box. After I was sure the alignment was good I used the pointed end of the 1/2" rod the mark the other end of the switch box and drilled a hole on that end so the rod can pass all the way through the give me the most amount of travel of the dial indicator possible.
I milled some flats onto the rod so I could mount a piece of 3/4" steel for the dial indicator mount. Then I milled a long flat for the set screw that controls the length of the shaft to seat on. I drilled and tapped the rectangular piece on both ends to hold the dial indicator and to mount it to the rod.
The rod is long enough to give maximum travel but not long enough to contact the gear train when fully retracted. If I need to move the carriage really close to the chuck it can be removed easily. The rod can be extended out to about 14" to measure travel anywhere along that length.
I hope you made a couple of extras , I've got an indicator at the ready. (If I ever get the lathe running again...)
_Dan
