Usually I'm a wood guy although I have access to vertical mills and was looking for an excuse to make something out of metal.
I loved my last AR15 (as a law abiding citizen with a banned-by-name lower I left it in an out-of-state storage facility when I immigrated to California and it was stolen before I could collect the upper and acquire an off-list lower), decided that recent legislative threats suggested acquiring a replacement soon, and availability issues were enough of an excuse for me to start some 0% projects.
1.5" end-mill .025" at a time with a final .010" conventional pass.
The first came out nicely, the rest did too.
On the first one I visually centered the clamping spot on one side of the forge line (oops) which isn't critical.
Operating under the theory that it'd be easier to mount each receiver on an angle plate so I wouldn't have to worry about stopping drilling/reaming before running into something solid I planned on the Ray Brandes (ray-vin.com) approach and passed on the optional clamping flats across the trigger guard front and rear that igluit4u cut.
After drilling the driver side holes in one I realized using the mill vise and a clamping pad beneath the receiver is a better idea. Drilling and reaming forces on the angle plate are orthogonal to the clamp jaws. I didn't make the rear clamp "gorilla tight" on my first one and got movement giving me 1-2 thousandths of ovality reaming my take down pin and safety holes (I first drilled 1/64" under-sized) which are still probably functional but made me feel bad. I flipped the clamp around so its pad straddled the forge line for a more secure attachment, really tightened it, and the trigger + hammer pin holes came out perfect.
I remain curious why drilling was OK with more force on the quill but reaming wasn't (Like I said - usually a wood guy).
With the forging sitting the mill vise sitting atop the appropriate pad being paranoid and setting the depth stop a dozen more times (there are seven through holes - take-down pin, rear trigger guard, safety, trigger, hammer, magazine release, and front pivot. The 3 fire control and pivot/take-down holes get drilled and reamed) shouldn't take me appreciably longer than indicating the side parallel to the ways on the angle plate.
