- Jan 2, 2014
- 8,853
the only drawback is it freaks the dogs out.
I can just about hear Scooby-Doo saying r-r-r-r--r---r-r-rhost!
-brino
Personally, I do not worry about a light coating of saw-dust too much. I've never had it cause a problem.
I worry about grinding dust/grit and move things around so the big machines with ways and slides are not "in the line of fire".
However.........one big DON'T, since you mentioned welding in that space.....
I needed a quick and simple dust cover for a welder when doing some sanding directly above it. I though I was clever by quickly fashioning something out of left-over 6-mil vapour barrier that was sitting right there. Using just a few folds and an office stapler I made a basic 5-sided "box" to fit the machine. It worked great for the sanding dust.
A few weeks later I was using one of the other welding machines and a spark landed on that cover.
I had no idea that vapour barrier was so flammable, it was self sustaining flames, melting and dripping.
I did not notice with the helmet on.
Luckily once I saw it I was able to grab an intact corner and throw it out the front door with no real damage....just a little melted plastic everywhere.
Play Safe!
-brino
What are anyone's thoughts about using Tyvek or equivalent ?
A good way to prevent rust is to run a dehumidifier in your shop. The lower the humidity the lower the dew-point, and as long as your machine is warmer than the dew-point it won't get condensation on it.
The thing is isn't Tyvelk expensive, a lot more than an old bed sheet etc.
Maybe the old mothball remedy would work with the bed sheets. I may have to rethink this !!
