Well, it seems to be working... -but not without a lot of chasing around. None of the motors my friend had were suitable. After making shaft adapters and trying two of them, I bit the bullet and bought a large general-purpose 2 Pole (3600 RPM) 120/240 motor. Since the 1/2, 1 and 1.5 HP units all weight about 18 lbs, what the heck, I bought the 1.5 HP unit because it was only 39 bucks more. It was on sale at Harbor Freight and it runs surprisingly smooth and quiet. It's a larger form factor than I wanted but the TPG does not get used all that often and, I might find other purposes for it later.
I had two wheels; a 4" 80 grit which I didn't have good luck with and a 5", 60 grit which did a nice job. I just ran a quick test piece which was the left-over hardened shaft from earlier in the project. I put a nice carbide cut on it, switched over to the TPG and gave it a shot. It works quite well. I followed-up with a buff and you can judge for yourself...
Pretty obvious... the motor is temporarily mounted because I just wanted a test run. Overall, it runs very quite and you can hear the air coming off the wheel. I still didn't receive one of the oil seals so, I make a temporary rubber gasket. Surprisingly, it's not leaking. I let it run for 30 minutes and the TPG housing just barely felt warm -maybe 10-15 degrees warmer than the lathe bed.
The picture right now shows a 1:1 sheave setup because the buffing wheel is only rated for 3600 RPM. If I stick with this motor, I'll need to make a sliding motor bracket to accommodate different diameter sheaves.
And here's piece after a 1 pass buff. It's pretty smooth. Now for the bad news... I was going to change back to the 5" #80 and in my frantic hurry to do so, I dropped it and chipped the edge -so it's in the garbage can where it belongs. Oh well, I guess it was time to get another one anyhow.
Over the next couple days, I'll put a few finishing touches on it -and hopefully the grease seal will arrive so we can do the final assembly with the permatex gasket stuff between the body segments. Right now, I just made gaskets out of thin paper -and oddly enough, it's not leaking... -Go figure.
I'll check back in a couple days on this project when the oil seal arrives. In the mean time, I'll install an oil drain plug and pretty-up the base a little.
Ray
