- Apr 7, 2014
- 343
I removed the end gear set today and found 2 bearings on the large gear were worn. I will clean up the gears and replace the bearings
Thanks for the photo I was wondering how the gear set looks like in the correct position .Thanks to everyone hear for your help.
Thats the correct position, but this morning it hit me that you need to make sure you have the right gears. The standard setup for standard threads is 40 tooth gears on both sides of the 127 tooth gear. Some metric threads on your lathe require the use of a 30 and/or 32 tooth gear. (Your photos a just blurry enough that I can't make out if the bottom gear on the bottom metric thread table is 30 or 32)
since your machine is set up for metric, you want to check to see if you have two 40 tooth gears.
chris
This is the standard setup.
This table shows the three possible configurations for metric threads on your lathe. Hopefully your machine was set up for the top one, which is the only one that uses two 40 tooth gears!
