- Apr 11, 2014
- 87
I’m not sure about the amount of carriage travel with one revolution of the threading dial? But, it definitely sounds like something moved on you. If you always start/engage on the same thread dial number, it will always cut on the same thread cut. Or maybe you did not engage the half nuts all the way, that will give you the problem you are having...Good Luck.
I am sure I didn't miss the settings and it is possible I did something wrong but I don't think so however the thread dial should have worked on any number or any line on this setting so somewhere something I did must have changed it. I just do not see what I did incorrectly.
maybe I need to look at the half nut to see if it is worn or something ... I don't know what went wrong as I thought I had it all set up and ran it right. ( beginners learning curve !! )
- - - Updated - - -
Wouldn't it be a bit$h if the thread dial screws were loose and it was skipping on the leadscrew.
nope that was the first thing I looked at...
