I have a jet 13x40, and when I first tried to cut 1/2 x 13 threads, it would cut a couple passes, just fine then take the thread off. First are you setting the cross feed to 29.5 degrees? if so that is most likely your problem, it should be 59.5 degrees. That was what I changed and cut real nice threads, something about it being an Asian lathe.
