- Feb 1, 2015
- 9,645
The third concept in the above video is the one employed in my lathe. The concept will not compensate for uneven wear in the lead screw, however.
What I did on my old and well used Atlas/Craftsman lathe was to add a second nut which was coupled to the original nut by a stiff compression spring. The nut is prevented from rotating by a key and the the spring forces the nuts against opposing faces, removing all backlash.
The nut that I used was actually an OEM nut left over from replacing it and I milled a slot in the cross slide apron to accommodate the boss on the OEM nut. The slot length only has to be longer the the boss diameter by one thread length. The backlash nut is located to the rear of the driving nut so that it works in concert with the cutting forces when the cross slide is feeding in. The spring compression force should be strong enough to overcome cutting forces when the cross slide is feeding out but not so strong as to make moving the cross slide difficult. A stronger spring will also result in increased wear.
The advantage of this setup is dynamic backlash compensation which results in uniform driving force. It also is possible to attain virtually zero backlash over the entire range of even a worn lead screw. One disadvantage is that there is an increase in driving force. Another is that the range of travel of the cross slide is reduced by the distance separating the two nuts.
