Thanks very much for the picture. That was a good mod.Well I messed up in my description of my mill mod a bit. I said that the nut passes through a hole in the plate I added, but it doesn't -- only the feed screw does. The hole is a fairly close fit so the nut has a decent contact area on the plate.
Before I made the plate, I cut a template out of paper to double-check the clearances.
