- Apr 28, 2013
- 84
I don't think it really makes any difference. You might need to rotate the dial a bit to get it to line up with the mark on the housing. You'll just have to engage the half-nut and see where it lines up at.
If the lines don't line up, you can usually loosen the mounting bolt and slide the thread dial in or out (towards or away from the carriage) until it hits a line or number when the half nut is engaged. I like mine timed just a tiny bit ahead, so by the time I react and throw the lever it ends up just a hair off of the line.
