Single Point Threading Between Centers
You must have a bench grinder, right?
Just use that, no worries. Costs free dollars and it'll work great.
I had a problem. I saw that I was able to make cuts as deep as .20 mm (10 divisions on the metric scale). After taking my son to work and then returning to the project, I dialed in 10 divisions on the Imperial scale. This is 30% more of a cut, and it busted my threading blade. Look at this carnage:
Way cool ! You couldn't make that on a cnc if you tried ! :encourage:
The way you are threading doesn't leave you much space for errors . I understand you're learning , but that could have been disasterous ! o_O
The Aloris P6 HSS insert has to be ground dead flat on top. You cannot do that with a wheel.
Erik, I was going to link to the belt sander that David recommended. If you use ceramic belt with it, it will definitely grind HSS just fine.
I respectfully disagree.
Even the Aloris website says "to sharpen, simply grind the top surface."
All you need to do is grind it flat.
Sure, a bench grinder will leave an **ever-so-slightly** convex surface, but just finish it flat with a stone if it bugs you.
Yes, a belt sander would be nice. Most new tools are nice. But you don't need one to sharpen your HSS insert.
I am going to have to move forward without a belt sander now because I financially ran myself into the ground with the PM-1660TL (and tooling) purchase. Also, my shop is full. Even if somebody gave me a bench grinder, I would have no place to put it indoors.
I have done fine with my bench grinder and diamond honing files for the HSS tool bits, even though the bench grinder lives outdoors.
So how do I grind the top of a P-6 flat with no belt sander? What if I get it close with a flap disc & then get it perfectly flat on the milling machine? A carbide end mill cuts the HSS P-6 just fine.
David,
I went with the Kalamazoo.
I probably should have gone on the cheap but I do like it.
These belt sanders are very handy for all sorts of things.
Here is how it is going. The thread relief OD is 16.1 mm for a minor diameter of 16.933 mm.
I don't know why I haven't used my Aloris threading tool-like yours??
I used it once, worked great and forgot about it.
Thinking about what Mikey said, "the edge needs to be perfectly flat". I can see using a HD tool room grinder or the U2. Then hone to a mirror finish for best results.
Looking really good man!!
The edge doesn't need to be flat . Think of it as a HSS tool bit . Grind it to so it works for the job .
David,
Those puppies are over $1000 in Canada... o_O
