- Mar 2, 2013
- 895
Make sure the oil port for bearings are clear of all metal debris I'm sure you knew that. Might wanna look at putting acouple strong magnets at the bottom.
Good point about the oil ports, it is also something @TakeDeadAim had mentioned also. There is no oil port, I was thinking there might be, there is a small dimple on the chuck side, but it does not go thru. There is no mark or hole inside the opening for the pulley side either.
What would be the way to approach this? The bearings have hard rubber inserts on each side, I would not call them sealed? I am not very knowledgable on bearings though. 6402-rz are the numbers on the bearing.
Any input, now is the time to make changes if any.
