- May 4, 2015
- 3,583
I would Ck the taper for raised chips and high spots. Then depending on there size I'd stone them and polish with a rod with a slot in the end about 1/2" , I'd get some every cloth fine cut and wrap it through the slot and around the rod chuck it in the chuck turn the lathe on and move the tailstock back and forth a few times adding some oil and polish it internAlly . It shouldn't take more then a couple times . Then clean it well reblue and Ck contact . If not good take a morse taper the same size and had some lapping compound and repeat till it's got good contact . Just an old way of doing it.
