The collar that you removed is the part that clamps the inner races of the two bearings against a shoulder on leadscrew, on the other side of the bearings. The inner ring clamps the outer races of the bearings to the table casting. The leadscrew should now be free to travel to the right, coming out of the bearings. You shouldn't need to remove the inner ring to pull the leadscrew.Cal
I made a 3 pin spanner and was able to get the first part out pretty easy, but it still is jammed
I see another 3 pin part that looks to be the same hole pattern but isnt,,
that particular part is very very hard to get off..
- - - Updated - - -
Is this the part that needs to come out as well?
The thread on the collets is a special thread, 0.775-18....
I got a set of collets from cheap tools and everything worked out good except for the threads on one of the collets.
It was pretty crappy and I was wondering what the pitch is so I can chase them a bit.( I dont have a thread gauge)
Or if by any luck there is die that I can get that will make the job easy.
The gib should have two notches in the right end for the right gib screw.Ok, I have been taking a break from this for a bit, but have been giving it penetrating oil and a few wacks every day since.. I removed the gib and I will post what that looks like tomorrow.. it has some specific looking notches milled into it and I didnt see those on Cals photo
Anyway, and all to say that there has been no remedy as of yet.. the table is free to move in the way described by you guys so I hope I am getting close.. but other then systematically taking this thing apart piece by piece, It isnt giving up the fight!!!
More updates tomorrow!!
