Never heard of that (not that I know a heck of a lot about surface grinding) but I use a single-point diamond mounted in a block that is then held fast with the magnetic chuck. Once it is trued up with the diamond point, then it is time to start grinding. Any dressing seems to me like it could then alter your just trued-up wheel.That is what i thought. Something i saw said trueing cleans up the wheel but you have to dress the wheel to wear away the bonding compound for the grit? I found it when i was looking up what a brake speed controller was.
That is what i thought and what i was taught.Never heard of that (not that I know a heck of a lot about surface grinding) but I use a single-point diamond mounted in a block that is then held fast with the magnetic chuck. Once it is trued up with the diamond point, then it is time to start grinding. Any dressing seems to me like it could then alter your just trued-up wheel.
If it is a DH612 it looks like it should be in the 885lb range. My 815 Bridgeport surface grinder is somewhere in that range too.How much do you think this could weigh?
