- Nov 26, 2017
- 1,517
It is a balance act between heat and wire feed. You have a starting point now. Take a piece of scrap and stay at the speed you have but increase the heat and see what you get. Then try reducing the speed and see what that produces.
Every machine is different and of course the speed at which you advance. I like a much hotter puddle to ensure I am getting good penetration. After that I just adjust the wire speed to fit my welding style.
You are well on your way. Repetition is the key. You will know by the looks of the bead when you are dialed in. Once you get that, everything is an adjustment from those settings to fit the material.
And don't forget, have some fun with it. For me, I try to make every weld look like it was welded by a machine. Don't always get it but that is my goal.
