- Nov 23, 2020
- 787
I also want to point out that my unit is showing feed rate at a rate 3x what it actually is, and I think this is an affliction for all the units.
Example - Today I ran a test where the DRO was showing feed rate at 21" per minute.
I ran the power feed for 15 seconds, and I measured the table travel. The table traveled 1.75" in 15 seconds, or 7" per minute. would this translate to 5 updates per second, and not 15?
Playing back at half speed you can see that the feed rate says 8.1 inches per minute and displayed value are 0.009 inches apart which works out to updating 15 times a second. Christian's video showed values 2.375mm apart with a feed rate of 34.9 mm/sec, which is also close to 15 updates a second.
Seems like a pretty slow update rate compared to other DROs.
The manual (from DROPros) mentions a "Vibration Filter" as a per-axis option which might cause the effect you are seeing.
Maybe see if that feature is set and try turning it off?
