- Jun 12, 2014
- 4,811
I would use the 15A D curve, I have it setup on my mill to run the axis drives which can have a high start-up current, internal power supplies and the DRO. I use two duplex sockets, one connected to the L1 and the other to L2, N and G are in common. I use 4 wire power to my mill and lathe so I do not need to run additional extension cords and power strips. If you are also running power supplies (12/24VDC) they spec. a 15A breaker, I have used smaller breakers in some of my earlier builds and the breaker would partially trip on power-up because of the in-rush current.
