- Sep 1, 2018
- 652
Only thing I changed was cutting tip insert. 12.00 here 5-6 years ago. Twenty pound cylinder refill here is 15.00.
Well I got an estimate for propane compatible torch nozzles for my current torch bodies.
New #6 rosebud $239.55
New brazing head $87.08
Two brazing tips $87.79
Total including tax is $462
A 20 lb propane tank swap is $30 at my corner Esso.
A B tank is $52 to fill.
$462 is a heck of a lot of acetylene at $22 difference per tank fill.
By brazing head I mean one of these:With regard to the items shown in Post #77, which items can only be used with acetylene? It looks the regulators are for oxygen and acetylene.
You got a quote for a rosebud, brazing head and brazing tips, so that may answer my question. What do you mean when you say “brazing head“?
Wouldn’t you need a regulator specific to propane?
The Victor rep said that I needed a propane reg also. So that's an additional expense.
Ah yes, I went brazing as I can't weld with propane.Thanks for clarifying. I call that a “welding tip”.
Long story made somewhat short is that I'm likely going to go oxy/acetylene. I cannot see dropping near $500 to save $22 on a tank of fuel.
Indeed, So I'll find a used B tank or I may spring for a tank. My LWS quoted me $200 for a full, exchangeable B tank.That is fantastic news because gas welding (to me, at least) is extremely satisfying!
Like I have said, gas welding plays out like TIG in slow motion. It is extremely good practice for TIG!
