- Jul 2, 2014
- 7,594
I read a manufacturer dissertation on VCI once and they said that the VCI is best when it is directly facing a surface. IOW, you have to surround something for best results.
Me? I use ATF, the cheaper the better, and have never had a rust problem on anything I have coated with it. I have also used ATF mixed with either paraffin wax or lanolin (using heat very carefully) to protect bare steel exposed to the elements. It is a thick goop and as long as the "goop" is brushed on thick it will last until ablated or rubbed off without any corrosion issues. Sort of a shop made equivalent of Cosmoline. Of course, I live in the California central valley, where cars can last many decades without rusting...
