- Jan 2, 2019
- 6,543
Is it the same as my C frame? Can you measure the ID of the threads?
Robert
Not a C frame at all, more like a welded rectangle.
Robert
My fear is that even if I buy a new cylinder ($150), I won't trust the C frame threads and I will need to use threaded rod and a plate as a failsafe...so maybe just start with the failsafe?
Next issue:
What am I going to get into if I disconnect the hydraulic line from the cylinder? Do I have to worry about bleeding out air when I reconnect? I have limited experience with hydraulics.
Jim- cylinder is about 2.20" diameter.
Robert
Yellow underneath. That paint didn't want to come off but will make a good primer. Even though I stripped it I think I may try to derust it. The table surface is pretty bad.
Robert
