I took apart the cross slide and compound for cleaning after about a month of use. I took some pictures if anyone is interested.
Here is the cross slide with the compound removed. I can't tell you what the discoloration in the middle there is but it didn't come off with scotch brite and it was covered in a layer of oil so that makes me think it isn't rust. You can see there that there doesn't appear to be a witness mark for the compound angle so once I figure out how to add one accurately, I will have to do so. You can see how the compound attaches with the t slots and nuts.
Here is the underside of the compound removed I was suprised to find that the motion screw was a standard 60 degree thread rather than an acme thread. The one on my HF was acme and I thought that was the standard. This could explain some of the troubles I have been having with it. I am having a hard time getting it to move smoothly without binding while still being tight enough to cut well. I don't think there is a way to convert this to an acme screw without making a new base for it so this will probably have to do for the forseeable future. You can also see the underside of the ways here. They aren't fantastic but they are good enough I think.
Now here is a problem. I had the hardest time focusing the camera on the finish for the compound gib but it looked like straight up tree bark. My glove would catch on it when I ran it over the top. This is on one of the sliding surfaces so that might explain some of the rough movement I was experiencing. This will certainly need some work. I may try to make one out of brass on my mill instead of trying to salvage this one.
I popped the cross slide off as well and I was suprised by what I found. It appeared that the ways have been scraped on this one. I am no expert but this is what I thought that would look like. You can also see where the oilers deposit the oil on the ways. This gib was in much better condition. As a side note, there is about 20 thousanths of movement I can't seem to remove from the cross slide. It seems to be independant of the backlash and only results from direct force applied to the cross slide. If that is confusing, I will turn the dial towards me say 5 turns, then reverse direction several turns (backlash is most certainly taken up) then pull towards myself from the far end, and it will slip and than catch with about 20 thousandths of movement. I can then turn the dial the same direction and it continues without taking up any backlash.
Here is the carriage portion of the cross slide. Everything here seemed to be in good condition. This was before I cleaned everything up and as you can see there is some debris on the ways. I am not sure if it was there when the machine was running or if it was deposited as I removed the cross slide. Here you can see that there is an acme screw that the cross slide attaches to using a black and a bolt. I am wondering if the acme screw is not properly secured and it is causing that 20 thousandths of movement I can't seem to locate.
I am still having trouble with the gearboxes leaking oil. I will contact Matt about that again soon. They told me the gaskets sometimes take some time to seal so I should give it a few weeks and if it didn't stop, get back in touch and we would go from there.
