@Ischgl99
I have a Starrett edge finder. Long ago I decided that using high rpm was probably going to increase the wear on it. So I just started using the lower rpm. Typically I use about or less than 100 rpm. Maybe each one of them is a bit different. Anyway yes mine moves off center with about a 0.001" step which is the smallest step my CNC pendant is set up to make. However, you have to be patient and watch for it. Anyway, it has been quite repeatable. My 940M has a lot of backlash and so I have to always use the finder via coming in from the same direction. I find the edge, commonly set the CNC software to a zero position, then back off well beyond the backlash and then move in again in the original direction to find the edge. It always seems to come in at zero or within a few ten thousands of it. If I then back off again and repeat I get the same thing. With my machine I don't believe must of anything that is less than 0.001".
The reason I mentioned the 50 rpm is because that is about as slow as my VFD will drive the spindle reliably. The VFD can vary the speed from 50 up to 1000 rpm ( gear position 1) so that is a factor of 20x in spindle speed, but I have actually never tried to cut anything at 50 rpm. I guess I have never open the cabinet to see what the VFD display says the Hz for a 50rpm or 1000 rpm is actually. Guess I should do that. Also, the max speed is 3200 when the gear on gear position 2 rather than 1.
@7milesup
Yes, my machine is quite noisy. However, a large portion of that is the fan motor. A good portion of the time during set up it is only the fan that is turning and it is still loud. I don't think I have noticed the noise level changing much with speed, but it must be a louder. ..... of course I am half deaf and I always try to wear my ear protection ... to save what little hearing I have left. I have thought about putting a thermal cut out switch on motor to switch the fan on and off.....as much of the time the machine is on it is not cutting anything.
