- Feb 1, 2015
- 9,622
You might try auto parts stores, farm supply stores, and marine equipment suppliers. I have used those connectors for many years . They come in polarized and non polarized versions.
What would happen if you replaced both of those with a more common male & female receptacle? Aren’t they just conducting electricity?
Edit: this discussion discourages that idea!
Can I splice a standard AC power plug onto a 2-pin DIN table lamp cord?
I've acquired a table lamp with a 20W 12V bulb (possibly from IKEA?). The cord terminates with a female 2-pin DIN (41529) connector that I do not have an adapter for. Am I correct to assume that it...electronics.stackexchange.com
If that won’t work, you could try *taking a picture head on*, and then doing a Google image search.
XLR connectors are available in different configurations but I’ve never used one for ac line voltage.The three prong plugs in the size are called a xlr plug used in the music industry and in battery power connections these days. They might offer in a two pin never checked.
There are many different applications, including some low voltage charging like on my dads scooter and 4 or 5 pin for clearcom headsets.XLR connections are for balanced audio signal, not for line voltage.
